Zum Hauptinhalt wechseln
Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
Was du brauchst
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: Schritt 1, Bild 1 von 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: Schritt 1, Bild 2 von 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: Schritt 1, Bild 3 von 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 2, Bild 1 von 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 2, Bild 2 von 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 3, Bild 1 von 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 4, Bild 1 von 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 4, Bild 2 von 2
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 5, Bild 1 von 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 5, Bild 2 von 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 5, Bild 3 von 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 6, Bild 1 von 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 6, Bild 2 von 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 6, Bild 3 von 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
Abschluss
Kue
301 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-2, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 271
