Disassembling Casio CZ-1000 Backplate
Einleitung
Zu Schritt 1 der AnleitungMany Casio CZ-1000 troubleshooting symptoms require opening up the back plate of the digital synthesizer. Inside the keyboard, a number of components are located under the two main motherboards. In this guide, we take you step by step through how to open up the back plate and remove the two main motherboards, giving access to the components below.
Was du brauchst
Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
Gently slide all the plugs out of their sockets.
