Zum Hauptinhalt wechseln
Disassembling Casio CZ-1000 Backplate
Jace Alexander
Jace Alexander und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 2, 2025
5 - 10 Minuten
Mittel
Many Casio CZ-1000 troubleshooting symptoms require opening up the back plate of the digital synthesizer. Inside the keyboard, a number of components are located under the two main motherboards. In this guide, we take you step by step through how to open up the back plate and remove the two main motherboards, giving access to the components below.
Was du brauchst
Werkzeuge
  1. Disassembling Casio CZ-1000 Backplate, Backplate: Schritt 1, Bild 1 von 2 Disassembling Casio CZ-1000 Backplate, Backplate: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Disassembling Casio CZ-1000 Backplate: Schritt 2, Bild 1 von 3 Disassembling Casio CZ-1000 Backplate: Schritt 2, Bild 2 von 3 Disassembling Casio CZ-1000 Backplate: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Disassembling Casio CZ-1000 Backplate: Schritt 3, Bild 1 von 3 Disassembling Casio CZ-1000 Backplate: Schritt 3, Bild 2 von 3 Disassembling Casio CZ-1000 Backplate: Schritt 3, Bild 3 von 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
Abschluss
Jace Alexander
181 Reputation
2 Anleitungen geschrieben
Cuesta, Team 60-3, Krynen Fall 2024 Mitglied von Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 33
