Zum Hauptinhalt wechseln
Disassembling Motorola i850 Keypad
Tony Chen
Tony Chen und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 28, 2014
10 - 15 Minuten
Mittel
A procedure in replacing the keypad of the device.
Was du brauchst
Werkzeuge
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: Schritt 1, Bild 1 von 1
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Disassembling Motorola i850 Keypad: Schritt 2, Bild 1 von 2 Disassembling Motorola i850 Keypad: Schritt 2, Bild 2 von 2
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Disassembling Motorola i850 Keypad, Battery: Schritt 3, Bild 1 von 1
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Disassembling Motorola i850 Keypad: Schritt 4, Bild 1 von 2 Disassembling Motorola i850 Keypad: Schritt 4, Bild 2 von 2
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Disassembling Motorola i850 Keypad, Keypad: Schritt 5, Bild 1 von 1
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  6. Disassembling Motorola i850 Keypad: Schritt 6, Bild 1 von 3 Disassembling Motorola i850 Keypad: Schritt 6, Bild 2 von 3 Disassembling Motorola i850 Keypad: Schritt 6, Bild 3 von 3
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Interior hardware inside the device can be easily damaged.
  7. Disassembling Motorola i850 Keypad: Schritt 7, Bild 1 von 2 Disassembling Motorola i850 Keypad: Schritt 7, Bild 2 von 2
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  8. Disassembling Motorola i850 Keypad: Schritt 8, Bild 1 von 2 Disassembling Motorola i850 Keypad: Schritt 8, Bild 2 von 2
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  9. Disassembling Motorola i850 Keypad: Schritt 9, Bild 1 von 3 Disassembling Motorola i850 Keypad: Schritt 9, Bild 2 von 3 Disassembling Motorola i850 Keypad: Schritt 9, Bild 3 von 3
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
  10. Disassembling Motorola i850 Keypad: Schritt 10, Bild 1 von 3 Disassembling Motorola i850 Keypad: Schritt 10, Bild 2 von 3 Disassembling Motorola i850 Keypad: Schritt 10, Bild 3 von 3
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
Abschluss
Tony Chen
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 34-56, Forte Spring 2010 Mitglied von Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,674
