Einleitung
i'll show you how to tear it down (without removing unnessesary parts like i did)
I'm not professional, so my lighting and photo quality isn't Perfect, i just don't have money to invest
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
it's a cheap low-end Music Phone
mine got wet so i decided to clean it up and look inside!
Flip it and pull the tab
the metal part should jump right off
after that remove the battery and sim card
i tried to remove the side panels but that didn't work so i tried on top and it did work (Jimmy worked fine)
after you unclip it you get that piece
remove these 2 TR6 Screws (mine were a bit blue)
open it up (clips on the bottom)
Remove the 4 TR6 Screws
remove the whole PCB and remove the clips from the display and it should pop off
2 of those fell of and i have NO idea where from (and i don't even care)
i cleaned it up and powered it up and it works (just make sure you don't short anything)
7 weitere Nutzer haben diese Anleitung absolviert.
