Zum Hauptinhalt wechseln
Disassembling Sony Vaio VGN-FW 590 Audio USB Board
Artem Nikulkov
Artem Nikulkov und 2 weitere Mitwirkende
Zuletzt aktualisiert am February 11, 2023
15 - 40 Minuten
Leicht
Anleitung eines Community-Mitglieds
This a simple process requiring only a small Phillips screwdriver and a slim flathead.
Note: A few trays for the screws, a wristband and an anti-static surface mat are ideal for safe handling of sensitive electronics.
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: Schritt 1, Bild 1 von 1
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: Schritt 2, Bild 1 von 1
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: Schritt 3, Bild 1 von 1
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: Schritt 4, Bild 1 von 1
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: Schritt 5, Bild 1 von 1
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: Schritt 6, Bild 1 von 1
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: Schritt 7, Bild 1 von 1
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 21,193
