Zum Hauptinhalt wechseln
Disassembling Yamaha YPG-225 Faceplate
Lonnie Bissmeyer
Lonnie Bissmeyer und 5 weitere Mitwirkende
Zuletzt aktualisiert am August 15, 2019
10 Minuten
Leicht
Benötigt Bessere Bilder
Removing the face plate is necessary for most repairs to this device. Removing the face plate is a relatively simple process, requiring only the removal of several screws.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: Schritt 1, Bild 1 von 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: Schritt 2, Bild 1 von 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: Schritt 3, Bild 1 von 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: Schritt 4, Bild 1 von 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: Schritt 5, Bild 1 von 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: Schritt 6, Bild 1 von 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: Schritt 7, Bild 1 von 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: Schritt 8, Bild 1 von 2 Disassembling Yamaha YPG-225 Faceplate: Schritt 8, Bild 2 von 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Abschluss
Cal Poly, Team 2-62, Propen Fall 2012 Mitglied von Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 1,716
