Zum Hauptinhalt wechseln
Door Stop Replacement
Khoa Bui
Khoa Bui und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 6, 2021
10 - 15 Minuten
Leicht
This page will help you to replace the broken door stop with a new door stop. The door stop is a useful attachment, and can prevent damage to any walls the door handle may come into contact with. If you or someone in your household is accustomed to slamming doors, you may want to use a door stop.
You will find the necessary components of the door stop (including screws) in a door stop package.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Door Stop Replacement, Door Stop: Schritt 1, Bild 1 von 3 Door Stop Replacement, Door Stop: Schritt 1, Bild 2 von 3 Door Stop Replacement, Door Stop: Schritt 1, Bild 3 von 3
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: Schritt 2, Bild 1 von 3 Door Stop Replacement: Schritt 2, Bild 2 von 3 Door Stop Replacement: Schritt 2, Bild 3 von 3
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: Schritt 3, Bild 1 von 2 Door Stop Replacement: Schritt 3, Bild 2 von 2
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: Schritt 4, Bild 1 von 3 Door Stop Replacement: Schritt 4, Bild 2 von 3 Door Stop Replacement: Schritt 4, Bild 3 von 3
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: Schritt 5, Bild 1 von 3 Door Stop Replacement: Schritt 5, Bild 2 von 3 Door Stop Replacement: Schritt 5, Bild 3 von 3
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: Schritt 6, Bild 1 von 2 Door Stop Replacement: Schritt 6, Bild 2 von 2
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: Schritt 7, Bild 1 von 3 Door Stop Replacement: Schritt 7, Bild 2 von 3 Door Stop Replacement: Schritt 7, Bild 3 von 3
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: Schritt 8, Bild 1 von 3 Door Stop Replacement: Schritt 8, Bild 2 von 3 Door Stop Replacement: Schritt 8, Bild 3 von 3
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: Schritt 9, Bild 1 von 2 Door Stop Replacement: Schritt 9, Bild 2 von 2
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: Schritt 10, Bild 1 von 3 Door Stop Replacement: Schritt 10, Bild 2 von 3 Door Stop Replacement: Schritt 10, Bild 3 von 3
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
Abschluss
Khoa Bui
198 Reputation
1 Anleitung geschrieben
York University, Team S1-G111, Woodhouse Fall 2020 Mitglied von York University, Team S1-G111, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G111
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 50
Insgesamt: 3,703
