Zum Hauptinhalt wechseln
Emerson Ceiling Fan  Flywheel Replacement
Tanner Brook
Tanner Brook und 3 weitere Mitwirkende
Zuletzt aktualisiert am December 15, 2022
10 Minuten
Mittel
Fehlende Schritte
If your Emerson ceiling fan is humming but the blades are not spinning, you most likely have a broken flywheel. It is a lot easier and cheaper to replace the flywheel yourself, rather than the whole fan.
Before using this guide, make sure you check to fan has power going to it. Check to make sure the circuit breaker is not flipped.
Replacing your flywheel is inexpensive and possible for most ceiling fan brands. If you do not know the brand of your fan, measure the flywheel once you remove it. Note the inside and outside diameter, and the locations and spaces between bracket and screw holes.
You will want to make sure power is turned off to the fan before you start to work on anything.
Was du brauchst
Werkzeuge
  1. Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: Schritt 1, Bild 1 von 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: Schritt 1, Bild 2 von 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: Schritt 1, Bild 3 von 3
    • Make sure power to the ceiling fan is off!
    • Use a Phillips #0 screwdriver to remove the ten 12.7 mm screws from the ceiling fan blades.
    • It is easier to work on the ceiling fan if you remove the motor.
  2. Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: Schritt 2, Bild 1 von 2 Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: Schritt 2, Bild 2 von 2
    • Remove light bulbs before working on switch housing.
    • Open the switch housing using a Phillips #0 screwdriver to remove the three 7.9 mm screws.
  3. Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: Schritt 3, Bild 1 von 2 Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: Schritt 3, Bild 2 von 2
    • Disconnect wires that are attached to the switch housing and the motor.
    • Make sure you know where to reconnect them.
  4. Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: Schritt 4, Bild 1 von 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: Schritt 4, Bild 2 von 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: Schritt 4, Bild 3 von 3
    • Remove the broken flywheel.
    • Make note of its exact placement on the shaft.
    • It may be a good idea to mark the location with a marker.
  5. Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: Schritt 5, Bild 1 von 3 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: Schritt 5, Bild 2 von 3 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: Schritt 5, Bild 3 von 3
    • Slide the new flywheel into place making sure all the holes line up.
    • Place any wires through the same holes as they were before
    • Replace any other parts you removed during the process.
  6. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: Schritt 6, Bild 1 von 2 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: Schritt 6, Bild 2 von 2
    • Reconnect the wires from the switch housing to the motor.
    • Make sure you connect the wires to the correct match.
  7. Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: Schritt 7, Bild 1 von 3 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: Schritt 7, Bild 2 von 3 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: Schritt 7, Bild 3 von 3
    • Screw back on the three 7.9 mm screws to the switch housing using a Phillips #0 screwdriver.
    • Screw the light bulbs back in.
  8. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: Schritt 8, Bild 1 von 3 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: Schritt 8, Bild 2 von 3 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: Schritt 8, Bild 3 von 3
    • Using a Phillips #0 screwdriver, reconnect ceiling fan blades by re-screwing on ten 12.7 mm Phillip screws.
    • If you removed the motor, reconnect it after blades are on.
Abschluss
Test your fan. It should be running quietly with no problems. If something is wrong make sure to double check you hooked the wires up correctly.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 14
Letzte 30 Tage: 29
Insgesamt: 4,272
