Zum Hauptinhalt wechseln
Epomaker SK64S Keyboard Switches Replacement
Muhammad Talha
Muhammad Talha und 2 weitere Mitwirkende
Zuletzt aktualisiert am November 20, 2022
1 - 2 Stunden
Leicht
Empfohlene Anleitung von Studierenden
Use this guide for replacing faulty key switches on an Epomaker SK64S Keyboard.
If a certain character will not type while using the keyboard it might be a faulty switch or dirt has piled up. Replacing the switch and cleaning the keyboard will get the keyboard working.
No special skills are required.
Use replacement switches that are compatible with the board. In this case any Gateron optical switch will work.
  1. Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: Schritt 1, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: Schritt 1, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: Schritt 1, Bild 3 von 3
    • Do not disassemble keyboard if it is connected to a power source.
    • Unplug the power cable.
  2. Epomaker SK64S Keyboard Switches Replacement: Schritt 2, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 2, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 2, Bild 3 von 3
    • Align the keycap puller with the keycap.
    • Pull the keycap straight out.
    • Remove all of the keys.
  3. Epomaker SK64S Keyboard Switches Replacement: Schritt 3, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 3, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 3, Bild 3 von 3
    • Fill the plastic container with water.
    • Add two drops of dish soap.
    • Put in the keycaps.
    • Let the keycaps soak for 30 minutes.
  4. Epomaker SK64S Keyboard Switches Replacement: Schritt 4, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 4, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 4, Bild 3 von 3
    • Take the keycaps out.
    • Place them on a paper towel.
    • Let the keycaps dry out.
  5. Epomaker SK64S Keyboard Switches Replacement: Schritt 5, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 5, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 5, Bild 3 von 3
    • Use an alcohol wipe to soak the cotton swab.
    • Clean the board by running the cotton swab along the board.
  6. Epomaker SK64S Keyboard Switches Replacement: Schritt 6, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 6, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 6, Bild 3 von 3
    • Align the switch puller with the faulty switch.
    • Pull the switch straight out.
  7. Epomaker SK64S Keyboard Switches Replacement: Schritt 7, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 7, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 7, Bild 3 von 3
    • Align the new key switch.
    • Push the key switch straight down.
  8. Epomaker SK64S Keyboard Switches Replacement: Schritt 8, Bild 1 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 8, Bild 2 von 3 Epomaker SK64S Keyboard Switches Replacement: Schritt 8, Bild 3 von 3
    • Align the keycap.
    • Push the keycap straight down.
    • Replace all the keycaps.
Abschluss
Type away!
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 988
