Zum Hauptinhalt wechseln
Fender Frontman 15r Power Input Jack Replacement
Will
Will und 4 weitere Mitwirkende
Zuletzt aktualisiert am January 28, 2014
15 Minuten
Leicht
If your device does not have power, replace the power input jack.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Fender Frontman 15r Power Input Jack Replacement, Back panel: Schritt 1, Bild 1 von 1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Power Input Jack Replacement: Schritt 2, Bild 1 von 1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Power Input Jack Replacement: Schritt 3, Bild 1 von 1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Power Input Jack Replacement, Mounting Bracket: Schritt 4, Bild 1 von 2 Fender Frontman 15r Power Input Jack Replacement, Mounting Bracket: Schritt 4, Bild 2 von 2
    • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
  5. Fender Frontman 15r Power Input Jack Replacement: Schritt 5, Bild 1 von 1
    • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
  6. Fender Frontman 15r Power Input Jack Replacement: Schritt 6, Bild 1 von 3 Fender Frontman 15r Power Input Jack Replacement: Schritt 6, Bild 2 von 3 Fender Frontman 15r Power Input Jack Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
  7. Fender Frontman 15r Power Input Jack Replacement: Schritt 7, Bild 1 von 3 Fender Frontman 15r Power Input Jack Replacement: Schritt 7, Bild 2 von 3 Fender Frontman 15r Power Input Jack Replacement: Schritt 7, Bild 3 von 3
    • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
  8. Fender Frontman 15r Power Input Jack Replacement, Power Input Jack: Schritt 8, Bild 1 von 2 Fender Frontman 15r Power Input Jack Replacement, Power Input Jack: Schritt 8, Bild 2 von 2
    • Before disconnecting the wires, label, make note of, or memorize each wire according to where it connects to the power input jack.
    • Disconnect the wire connectors from the back of the input jack by pulling them away from the jack.
  9. Fender Frontman 15r Power Input Jack Replacement: Schritt 9, Bild 1 von 2 Fender Frontman 15r Power Input Jack Replacement: Schritt 9, Bild 2 von 2
    • Use Philips #1 Screwdriver to unscrew the two 12.1 mm screws on the exterior of the power input jack.
    • Hold the nut in place while unscrewing the 12.1 mm screws using a pair of needle nose pliers to prevent it from spinning.
  10. Fender Frontman 15r Power Input Jack Replacement: Schritt 10, Bild 1 von 1
    • Pull the power input jack out of the mounting bracket.
Abschluss
Once the old power jack is removed, to install the replacement power jack, follow the guide in reverse.
Will
46 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-30, Regan Fall 2012 Mitglied von Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 7,728
