Zum Hauptinhalt wechseln
FujiFilm FinePix A340 Flash Unit Replacement
Cody
Cody und 6 weitere Mitwirkende
Zuletzt aktualisiert am January 9, 2025
40 Minuten - 1 Stunde
Schwierig
Action Shots
Fehlende Schritte
Uneinheitliche Bilder
Benötigt Bessere Bilder
This guide explains how to replace the flash unit of a FujiFilm FinePix A340 camera.
The flash unit is a mechanism within a camera that creates a "flash" or quick burst of light while a photo is taken to illuminate the image. If the "flash" function of your camera is not working, you may need to replace your flash unit.
Note that this guide involves soldering, or using a special tool called a soldering iron to delicately weld parts together.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 2, Bild 1 von 3 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 2, Bild 2 von 3 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 2, Bild 3 von 3
    • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 3, Bild 1 von 2 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 3, Bild 2 von 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 6, Bild 1 von 1
    • Push both blue switches away from the holding device to detach the LCD ribbon.
    • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 7, Bild 1 von 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 8, Bild 1 von 1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 10, Bild 1 von 2 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 10, Bild 2 von 2
    • Remove the black sticky tape from the circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 11, Bild 1 von 2 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 11, Bild 2 von 2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing the assembly as to not break any solder leads or damage the lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 12, Bild 1 von 2 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 12, Bild 2 von 2
    • Remove the motherboard by pulling it straight away from the assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: Schritt 13, Bild 1 von 1
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: Schritt 14, Bild 1 von 2 FujiFilm FinePix A340 Flash Unit Replacement: Schritt 14, Bild 2 von 2
    • Desolder the flash unit at its three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
    • Learn more about electronics soldering here.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cody
47 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-11, Maness Spring 2010 Mitglied von Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 4,005
