Zum Hauptinhalt wechseln
Fujifilm Fine S1800 LCD Screen Replacement
Ryan Rockford
Ryan Rockford und 8 weitere Mitwirkende
Zuletzt aktualisiert am January 5, 2024
20 - 25 Minuten
Mittel
Bessere Einleitung
This guide explains how to replace the old broken LCD screen.
Was du brauchst
Werkzeuge
  1. Fujifilm Fine S1800 LCD Screen Replacement, Back Cover Assembly: Schritt 1, Bild 1 von 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Fine S1800 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Fine S1800 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Fine S1800 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Fujifilm Fine S1800 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: Schritt 5, Bild 1 von 2 Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: Schritt 5, Bild 2 von 2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Fine S1800 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Fine S1800 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
Abschluss
Ryan Rockford
618 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 8-6, Eyestone Spring 2017 Mitglied von USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 595
