Zum Hauptinhalt wechseln
Fujifilm FinePix S4200 LCD Screen Replacement
Jackie Acevedo
Jackie Acevedo und 6 weitere Mitwirkende
Zuletzt aktualisiert am April 21, 2020
15 Minuten
Mittel
Fehlende grundständige Anleitungen
Replace the LCD screen if you are experiencing blurry pictures, or if you have a cracked screen.
Was du brauchst
Werkzeuge
  1. Fujifilm FinePix S4200 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 5, Bild 1 von 3 Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 5, Bild 2 von 3 Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 5, Bild 3 von 3
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 10, Bild 1 von 1
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 11, Bild 1 von 2 Fujifilm FinePix S4200 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jackie Acevedo
340 Reputation
2 Anleitungen geschrieben
CSU Fullerton, Team 1-4, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-4, Bruce Fall 2015
CSUF-BRUCE-F15S1G4
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Ou peut on trouver cet écran ?
lise.didion - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 21
Insgesamt: 1,679
