Fujifilm FinePix XP10SE LCD Replacement
Was du brauchst
Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
Use a T5 Torx bit to secure the exterior decorative cover of the device.
Locate the securing tabs of the housing unit.
Using the spongerslowly work your way around the outside of the case using the sponging tool to pry open the case.
*** Take extreme caution when doing this being careful not to break the securing tabs of the housing.
Once the case is open locate the Ribbon cable attachment for the LCD screen.
Carefully ensure that the LCD screen is free from all attachments and any tape securing the ribbon cable is released.
Gently lift up on the black securing bar of the ribbon cable in order to free it from the units motherboard, thus releasing the LCD from the computer.
Eine weitere Person hat diese Anleitung absolviert.
