Zum Hauptinhalt wechseln
Fujifilm FinePix XP50 Rear Case Replacement
Paulo Abalos
Paulo Abalos und 6 weitere Mitwirkende
Zuletzt aktualisiert am April 30, 2020
10 - 20 Minuten
Mittel
Action Shots
Use this guide if the rear case is cracked or broken and needs to be replaced. Replacing the rear case requires removing plenty of screws which may prove difficult if they are stripped.
Was du brauchst
Werkzeuge
  1. Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 3 Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 3 Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
    • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm FinePix XP50 Rear Case Replacement: Schritt 2, Bild 1 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 2, Bild 2 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 2, Bild 3 von 3
    • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm FinePix XP50 Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm FinePix XP50 Rear Case Replacement: Schritt 4, Bild 1 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 4, Bild 2 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 4, Bild 3 von 3
    • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm FinePix XP50 Rear Case Replacement: Schritt 5, Bild 1 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 5, Bild 2 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 5, Bild 3 von 3
  6. Fujifilm FinePix XP50 Rear Case Replacement: Schritt 6, Bild 1 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 6, Bild 2 von 3 Fujifilm FinePix XP50 Rear Case Replacement: Schritt 6, Bild 3 von 3
    • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Baylor, Team 2-4, Grigsby Spring 2015 Mitglied von Baylor, Team 2-4, Grigsby Spring 2015
BU-GRIGSBY-S15S2G4
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
where can I buy the Fujifilm FinePix XP50 Rear Case?
CO - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 825
