Gateway MS2370 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to remove the battery from the Gateway MS2370 laptop.
Was du brauchst
Werkzeuge
Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
2 weitere Personen haben diese Anleitung absolviert.
