Zum Hauptinhalt wechseln
Goodman Furnace Blower Motor Replacement
Ryan W
Ryan W und eine weitere beteiligte Person
Zuletzt aktualisiert am December 20, 2023
1 Stunde
Mittel
Anleitung eines Community-Mitglieds
This will serve as a walk-through in the disassembly and repair of a blower motor for any Goodman branded home furnace.
  1. Goodman Furnace Blower Motor Replacement, Opening the Unit: Schritt 1, Bild 1 von 3 Goodman Furnace Blower Motor Replacement, Opening the Unit: Schritt 1, Bild 2 von 3 Goodman Furnace Blower Motor Replacement, Opening the Unit: Schritt 1, Bild 3 von 3
    • Ensure all power cables are disconnected from the unit and/or wall prior to attempting this guide.
    • Gloves are highly recommended to avoid injuries from any sharp edges.
    • Unscrew the two screws located on the rear side of the unit.
    • Remove the doors and set them aside.
    • A 3/8" screwdriver will be the easiest method of completing this step.
  2. Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: Schritt 2, Bild 1 von 3 Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: Schritt 2, Bild 2 von 3 Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: Schritt 2, Bild 3 von 3
    • It is strongly advised that you take a picture of the wire configuration prior to removal for reference when connecting the new motor.
    • Disconnect the brown wire from the top of the motor.
    • Disconnect the second brown wire from the bottom of the unit.
    • Remove the white, blue, red, orange, and black wires from the controller board.
  3. Goodman Furnace Blower Motor Replacement, Removing the Motherboard Screws: Schritt 3, Bild 1 von 2 Goodman Furnace Blower Motor Replacement, Removing the Motherboard Screws: Schritt 3, Bild 2 von 2
    • Unscrew both screws connected the motherboard to the cylindrical motor container.
    • The screws are located on top and bottom sides of the plate holding the motherboard.
  4. Goodman Furnace Blower Motor Replacement, Removing the Motor Container: Schritt 4, Bild 1 von 2 Goodman Furnace Blower Motor Replacement, Removing the Motor Container: Schritt 4, Bild 2 von 2
    • Unscrew the cylindrical motor housing from the unit.
    • There are two screws located at each side of the top corner of the container.
    • Grab the motor container with two hands and pull it out of the unit.
    • Place the motherboard to the side.
  5. Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: Schritt 5, Bild 1 von 3 Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: Schritt 5, Bild 2 von 3 Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: Schritt 5, Bild 3 von 3
    • Turn the motor container on its side, with the wires pointing up.
    • Unscrew the 3 screws attaching the motor to the housing.
    • Take the yellow wire out of the screw.
    • Use a wrench to remove the bolt from the shaft of the motor, located on the opposite side.
    • If rust has accumulated on the motor shaft, you may wish to use sandpaper to remove it to make the motor easier to remove.
    • Firmly grasp the motor from the side where the screws were previously located and pull to remove it.
    • The white label on the side of the motor contains the model number of the blower motor which you may use as a reference when ordering a replacement, if necessary.
  6. Goodman Furnace Blower Motor Replacement, Inserting the Replacement Motor: Schritt 6, Bild 1 von 2 Goodman Furnace Blower Motor Replacement, Inserting the Replacement Motor: Schritt 6, Bild 2 von 2
    • Insert the new motor into the motor housing.
    • Ensure the wires are at the front of the assembly.
    • Tighten the bolt at the shaft of the motor that you removed in the previous step.
    • You may wish to get the bolt started with your hands, and finish tightening with the wrench.
    • Ensure the flat surface is aligned with the screw hole prior to tightening with the wrench.
  7. Goodman Furnace Blower Motor Replacement, Reassembly Tips: Schritt 7, Bild 1 von 1
    • Ensure the fan blades are freely spinning prior to continuing.
    • When assessing the fan blade, ensure you either keep your hands flat or wear gloves to avoid injury.
    • Utilize your reference photo when rewiring the unit.
Abschluss
Ryan W
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 21
Letzte 30 Tage: 101
Insgesamt: 1,296
