Einleitung
Follow this guide to replace a dead or worn-out battery in your HMD Pulse Pro smartphone.
Your phone's lithium-ion battery has a limited lifespan. If your phone dies quickly and doesn't hold a charge, it may be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Was du brauchst
Unplug all cables from your phone and completely power it down.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
Position the opening pick straight down and slide it along the left edge to begin unclipping the back cover.
Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
Carefully flip your phone over so the back cover is facing up.
Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
Insert an opening pick between the right edge of the motherboard cover and frame.
Twist the pick to fully unclip the cover.
Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
Use your fingers to carefully peel the three plastic tabs from the left side of the battery.
With one hand, fold the clear outer tabs out of the way of the battery and firmly hold them down to secure the frame.
With your free hand, grip the green center pull tab and pull straight up to fully separate the battery adhesive.
Lay the battery over the right edge of your phone.
Remove the battery and its film.
If the adhesive in the battery recess is still sticky, you don't need to replace it.
If the adhesive isn't sticky, use a spudger and tweezers to peel up and remove the two pieces of battery adhesive. Then, apply the new adhesive to the frame and remove the plastic liners.
Firmly press the battery into its recess so the cable is on the top edge and the three tabs are on the left edge.
For optimal performance, calibrate your newly installed battery after reassembling your phone.
