Zum Hauptinhalt wechseln
HP 15-dw0037wm Display Assembly Replacement
Emily Davila
Emily Davila und eine weitere beteiligte Person
Zuletzt aktualisiert am December 19, 2024
20 Minuten
Mittel
Is your HP 15-dw0037wm not closing properly or making squeaky and weird noises? It's likely that your laptop's hinges are malfunctioning. The hinges are vital to giving you the proper viewing angle and in ensuring the safety of your screen. If your laptop gets stuck while closing or is making concerning noises then it's likely you need to change your device's hinges.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP 15-dw0037wm Display Assembly Replacement, Lower Case: Schritt 1, Bild 1 von 2 HP 15-dw0037wm Display Assembly Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm Display Assembly Replacement: Schritt 2, Bild 1 von 2 HP 15-dw0037wm Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm Display Assembly Replacement: Schritt 3, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 3, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm Display Assembly Replacement, Display Assembly: Schritt 4, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement, Display Assembly: Schritt 4, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement, Display Assembly: Schritt 4, Bild 3 von 3
    • Detach the coaxial connector by grabbing it securely from the gold colored metal section and gently lifting upwards.
    • Don't tug on it from the white end or towards the side. It is likely to get damaged.
  5. HP 15-dw0037wm Display Assembly Replacement: Schritt 5, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 5, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 4 mm Phillips screws that secure the two hinges.
  6. HP 15-dw0037wm Display Assembly Replacement: Schritt 6, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 6, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 6, Bild 3 von 3
    • Flip up the black locking flap on the ZIF connector.
    • Disconnect the display cable.
  7. HP 15-dw0037wm Display Assembly Replacement: Schritt 7, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 7, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 7, Bild 3 von 3
    • Use an opening tool to lift up the hinges.
    • Grab the hinge and pull it outwards.
    • Repeat onto the other hinge.
  8. HP 15-dw0037wm Display Assembly Replacement: Schritt 8, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 8, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 8, Bild 3 von 3
    • Gently grab the plastic cover and use both hands to lift it slowly from one side to the other.
    • Lift up the plastic cover to fully detach it.
  9. HP 15-dw0037wm Display Assembly Replacement: Schritt 9, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 9, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 9, Bild 3 von 3
    • Remove the six silver 4 mm Phillips screws that secure the hinges to the screen.
    • Remove the two black 4 mm Phillips screws.
    • Be careful when removing the screws because it's possible that the foil underneath and the threaded hole itself can come off.
  10. HP 15-dw0037wm Display Assembly Replacement: Schritt 10, Bild 1 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 10, Bild 2 von 3 HP 15-dw0037wm Display Assembly Replacement: Schritt 10, Bild 3 von 3
    • Lift up the hinge from the lower half and gradually separate it from the screen.
    • Repeat on the other side.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Emily Davila
651 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 109
