Zum Hauptinhalt wechseln
HP 15-dw0037wm Hard Drive Replacement
Emily Davila
Emily Davila und eine weitere beteiligte Person
Zuletzt aktualisiert am December 19, 2024
5 Minuten
Mittel
Have you noticed that your HP 15-dw0037wm is suddenly out of storage, making weird noises and or you're receiving a lot of error messages? It's possible that your laptop's hard drive (HDD) needs to be replaced. Your hard drive is responsible for data storage for things like applications, music, documents, etc. If your laptop is overheating or getting corrupted files then you likely need to replace the hard drive. Before replacing the hard drive make sure to back up your data.
Was du brauchst
Werkzeuge
  1. HP 15-dw0037wm Hard Drive Replacement, Lower Case: Schritt 1, Bild 1 von 2 HP 15-dw0037wm Hard Drive Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP 15-dw0037wm Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP 15-dw0037wm Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP 15-dw0037wm Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 HP 15-dw0037wm Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 HP 15-dw0037wm Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove the two 4 mm Phillips screws on the metal bracket.
    • Remove the one 4 mm Phillips screw that secures the board attached to the hard drive.
  5. HP 15-dw0037wm Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP 15-dw0037wm Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP 15-dw0037wm Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Gently lift up the black ZIF locking flap.
    • Disconnect the ribbon cable.
  6. HP 15-dw0037wm Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP 15-dw0037wm Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift up the hard drive.
    • Remove the single 4 mm screw that secures the metal bracket to the hard drive.
    • The one screw for this one is thicker than the others, 3 mm compared to 2 mm.
  7. HP 15-dw0037wm Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP 15-dw0037wm Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP 15-dw0037wm Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Pull the metal bracket down slightly and pull to the side.
    • Gently grab the board and pull it to the side.
    • Don't pull down to remove the chip as it can badly damage the port.
Abschluss
Emily Davila
651 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 28
Insgesamt: 89
