Zum Hauptinhalt wechseln
HP 15-dw0037wm RAM Replacement
Emily Davila
Emily Davila und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 19, 2024
5 Minuten
Mittel
If your HP 15-dw0037wm is freezing or experiencing performance issues, it could be due to faulty or insufficient RAM, which may need replacement. RAM (Random Access Memory) temporarily stores data your computer needs to access quickly over time, defective or outdated RAM can cause instability. Before replacing the RAM, always ensure your device is powered down before starting the replacement process.
Was du brauchst
Werkzeuge
  1. HP 15-dw0037wm RAM Replacement, Lower Case: Schritt 1, Bild 1 von 2 HP 15-dw0037wm RAM Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm RAM Replacement: Schritt 2, Bild 1 von 2 HP 15-dw0037wm RAM Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm RAM Replacement: Schritt 3, Bild 1 von 3 HP 15-dw0037wm RAM Replacement: Schritt 3, Bild 2 von 3 HP 15-dw0037wm RAM Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm RAM Replacement, RAM: Schritt 4, Bild 1 von 3 HP 15-dw0037wm RAM Replacement, RAM: Schritt 4, Bild 2 von 3 HP 15-dw0037wm RAM Replacement, RAM: Schritt 4, Bild 3 von 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
  5. HP 15-dw0037wm RAM Replacement: Schritt 5, Bild 1 von 3 HP 15-dw0037wm RAM Replacement: Schritt 5, Bild 2 von 3 HP 15-dw0037wm RAM Replacement: Schritt 5, Bild 3 von 3
    • Grab the RAM by the exposed side and gently remove it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Emily Davila
651 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 128
