Zum Hauptinhalt wechseln
HP Chromebook 14-ca061dx Daughterboard Replacement
Jean Arevalo
Jean Arevalo und 4 weitere Mitwirkende
Zuletzt aktualisiert am December 21, 2019
15 Minuten
Mittel
Studierende im Gange!
Follow this guide if the USB-A or USB-C port on the left side of the HP Chromebook 14-ca061dx isn’t functioning and you have decided to replace the ports. The part that needs to be replaced is the daughterboard. To do this follow this guide and be careful while removing the parts.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Chromebook 14-ca061dx Daughterboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 5, Bild 3 von 3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 6, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 6, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 6, Bild 3 von 3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 7, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 7, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 7, Bild 3 von 3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Daughterboard Replacement, Daughterboard: Schritt 9, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Daughterboard: Schritt 9, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Daughterboard: Schritt 9, Bild 3 von 3
    • Peel back the plastic covering the cables connecting the motherboard to the daughterboard.
    • Use the spudger tool to flip up the black plastic pieces from both cables.
    • Pull both cables toward the right to remove from the daughterboard.
    • Be sure to remove the cables carefully because they are fragile.
  10. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 10, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 10, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 10, Bild 3 von 3
    • Peel back the plastic covering from the smallest blue and white cable.
    • Flip up the white plastic piece using the spudger.
    • Pull the blue cable toward the right to remove it.
    • Be sure to remove the cable carefully because it is fragile.
  11. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 11, Bild 1 von 2 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 11, Bild 2 von 2
    • Remove two 4mm Phillips #0 screws.
    • Remove the daughterboard from the Chromebook.
Abschluss
Jean Arevalo
778 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 462
