Zum Hauptinhalt wechseln
HP Compaq 2510p RAM Replacement
Nathan Pereira
Nathan Pereira und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 26, 2016
10 Minuten
Leicht
This guide requires only two screws to be removed with Phillips head screwdriver. Once the panel is removed, the ram can easily be pulled out.
Was du brauchst
Werkzeuge
  1. HP Compaq 2510p RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: Schritt 3, Bild 1 von 1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: Schritt 4, Bild 1 von 1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: Schritt 5, Bild 1 von 1
    • Remove the old RAM by lifting it upwards, then pulling.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 893
