HP Compaq 2510p RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide requires only two screws to be removed with Phillips head screwdriver. Once the panel is removed, the ram can easily be pulled out.
Was du brauchst
Werkzeuge
Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
3 weitere Personen haben diese Anleitung absolviert.
