HP Compaq 2510p WiFi Card Replacement
Einleitung
Zu Schritt 1 der AnleitungHow to remove and replace WiFi card in the HP Compaq 2510p.
Was du brauchst
Flip the laptop over and locate the RAM cover plate towards the left of the laptop. There will be two screws located on the panel.
Locate the screws at the top of the card and use your Philips screwdriver to remove them.
Lift the card from underneath the top, using the spudger to leverage the card upwards. Then pull to release the card.
Pull on each of the wires connected to the card. They will easily pop off and the WiFi card will be released.
Eine weitere Person hat diese Anleitung absolviert.
