Zum Hauptinhalt wechseln
HP Compaq 515 Battery Replacement
Kirsten Harnden
Kirsten Harnden und 2 weitere Mitwirkende
Zuletzt aktualisiert am June 5, 2018
5 Minuten
Sehr einfach
This replacement guide is quite simple for people who aren't very tech savvy. It is fast and simple to do on your own. This replacement would be necessary if the device can't run without being plugged into a power source. Make sure the laptop is off before proceeding with the replacement.
  1. HP Compaq 515 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over, the battery is located along the top of the device.
  2. HP Compaq 515 Battery Replacement: Schritt 2, Bild 1 von 2 HP Compaq 515 Battery Replacement: Schritt 2, Bild 2 von 2
    • There are two rectangular tabs on the battery. With both hands, push each tab towards the center to free the battery from the device.
    • keeping the tabs pushed in, slide the battery upwards.
  3. HP Compaq 515 Battery Replacement: Schritt 3, Bild 1 von 1
    • The battery should pop off and release from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kirsten Harnden
259 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 394
