Zum Hauptinhalt wechseln
HP Compaq 6710b Keyboard Replacement
Was du brauchst
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Compaq 6710b Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Compaq 6710b Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Keyboard Replacement: Schritt 3, Bild 1 von 2 HP Compaq 6710b Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Khulan Orgil
1.120 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-2, Maness Spring 2015 Mitglied von Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Mitglieder
2 Kommentare
No parts required to *replace* the keyboard?
David - Antwort
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 31
Insgesamt: 4,767
