Einleitung
Make sure your computer is off and battery is out before attempting to replace your wireless adaptor.
Was du brauchst
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Using a Phillips #1, unscrew the 5mm screw on the bottom of the laptop
Remove the back cover plate.
Using the Phillips #1 screwdriver, unscrew the 2 3mm screws.
You can now take out the adaptor.
Fast fertig!
Abschluss
