Zum Hauptinhalt wechseln
HP Compaq NC6120 Cooling Fan Replacement
Mateo Cuellar
Mateo Cuellar und 5 weitere Mitwirkende
Zuletzt aktualisiert am March 5, 2025
15 - 25 Minuten
Mittel
Aufzählungszeichen!
Bessere Einleitung
Studierende im Gange!
If your HP Compaq NC6120 is overheating, it might be time to clean or replace the fan. This repair is usually needed when the internal cooling system isn't working properly due to dust buildup or when the fan is malfunctioning. A fan that isn't working properly can lead to reduced performance or even permanent damage to the laptop's components.
Removing and servicing the fan can resolve these issues. The process is relatively straightforward after disassembling the laptop, but it requires carefully handling delicate internal parts. No special skills are required, but it's important to ensure you have the correct replacement fan.
Was du brauchst
Werkzeuge
  1. HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: Schritt 1, Bild 1 von 1
    • Locate cooling fan directly to the left of copper heat sink.
  2. HP Compaq NC6120 Cooling Fan Replacement: Schritt 2, Bild 1 von 2 HP Compaq NC6120 Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Locate the black/grey/brown colored cord and carefully disconnect it from the motherboard.
    • Place cord off to the side so that it is out of the way.
  3. HP Compaq NC6120 Cooling Fan Replacement: Schritt 3, Bild 1 von 2 HP Compaq NC6120 Cooling Fan Replacement: Schritt 3, Bild 2 von 2
    • Locate and remove the two 7.0mm Phillips #1 screws on the top left and top right corners of the cooling fan.
  4. HP Compaq NC6120 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 HP Compaq NC6120 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the fan from its spot.
Abschluss
Mateo Cuellar
601 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 17-4, Forte Spring 2015 Mitglied von Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 711
