Zum Hauptinhalt wechseln
HP Compaq NC6120 RAM Replacement
Keenan
Keenan und 7 weitere Mitwirkende
Zuletzt aktualisiert am May 29, 2024
10 - 20 Minuten
Sehr einfach
Replacing the RAM to an HP Compaq NC6120 is an effective way to maximize the computer's running speed. It's a simple replacement, as HP made the compartment easily accessible and user-friendly. If the computer is running slowly, and you know that no parts are broken, replacing the RAM is one of the first steps that should be done to make your computer run faster.
Was du brauchst
Werkzeuge
  1. HP Compaq NC6120 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Locate the plastic casing covering the RAM chip.
    • The plastic casing is found on the back side of the laptop, in the middle of the base panel.
  2. HP Compaq NC6120 RAM Replacement: Schritt 2, Bild 1 von 2 HP Compaq NC6120 RAM Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the M2 screw securing the plastic casing covering the RAM chip.
    • Now remove the plastic casing and you should see the RAM chip.
  3. HP Compaq NC6120 RAM Replacement: Schritt 3, Bild 1 von 3 HP Compaq NC6120 RAM Replacement: Schritt 3, Bild 2 von 3 HP Compaq NC6120 RAM Replacement: Schritt 3, Bild 3 von 3
    • Remove the RAM chip from underneath the casing.
    • It should easily pop out.
  4. HP Compaq NC6120 RAM Replacement: Schritt 4, Bild 1 von 1
    • Replace the RAM chip with a new RAM chip.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Keenan
494 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-4, Forte Spring 2015 Mitglied von Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 1,714
