HP Compaq Presario V5303NR RAM Stick Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will walk the reader through the process of locating, removing and replacing the RAM Stick in the Compaq Presario. This process will need to be done if the RAM Stick is damaged or corrupted. Alternatively, this can also be followed to upgrade the RAM, as a way of giving the computer more processing power. For older computers like this one, this is an essential process for keeping it relevant.
Was du brauchst
Turn laptop bottom-side up.
Push the battery latch to the left position to unlock the battery.
Lift the battery out of its socket.
Remove the circular, black piece of plastic shown in the picture by pulling it away from the air vent.
Use the Phillips #00 screwdriver to loosen, but not remove, the two 4mm screws shown in the picture.
Pull the highlighted latches away from the sides of the RAM Stick to unlock it.
