HP Compaq Pro 6300 RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungA guide to upgrading the RAM in the HP Compaq Pro 6300.
Put your thumbs on the two tabs surrounding the RAM sticks and push down.
If you need more room, you can unplug the SATA cables that connect the hard drive and DVD drive to the computer- just make sure you plug them back in when you finish.
Pull the module out by the top or the sides. Take care not to touch the delicate pins at the bottom and the chips on the surface.
Insert the new module, lining the notch on the module with the notch in the slot.
Push down on the module until you hear both tabs lock into the notches.
