HP Compaq nc6400 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will take you through the process of replacing the battery in an HP Compaq nc6400 Laptop. You will need the correct replacement battery for your laptop to complete the installation.
Locate the battery lock below the battery labeled one.
Slide the lock all the way to the left to release the left lock of the battery.
Locate the lock labeled two at the bottom right corner below the battery.
Slide and hold the lock to the left.
4 weitere Personen haben diese Anleitung absolviert.
