Zum Hauptinhalt wechseln
HP Compaq nc6400 Optical Drive Replacement
Chad Williams
Chad Williams und 7 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2024
15 - 30 Minuten
Mittel
This guide will take you through the process of replacing the optical drive in a HP Compaq nc6400 Laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
Was du brauchst
Werkzeuge
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. HP Compaq nc6400 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: Schritt 5, Bild 1 von 2 HP Compaq nc6400 Optical Drive Replacement, Optical Drive: Schritt 5, Bild 2 von 2
    • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
  6. HP Compaq nc6400 Optical Drive Replacement: Schritt 6, Bild 1 von 2 HP Compaq nc6400 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Press and release the eject icon to partially eject the optical drive.
    • Use of a spudger may be necessary to pry open the optical drive.
  7. HP Compaq nc6400 Optical Drive Replacement: Schritt 7, Bild 1 von 1
    • Grasp the sides and pull the optical drive out.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 14-6, Forte Fall 2013 Mitglied von Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 4,673
