Zum Hauptinhalt wechseln
HP Compaq nc6400 Screen Replacement
Luis Vazquez
Luis Vazquez und 5 weitere Mitwirkende
Zuletzt aktualisiert am July 15, 2014
30 Minuten
Mittel
This guide will take you through the process of replacing the screen on an HP Compaq nc6400 Laptop. You will need the correct replacement screen for your laptop to complete the installation.
Was du brauchst
Werkzeuge
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. HP Compaq nc6400 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: Schritt 3, Bild 1 von 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Screen Replacement: Schritt 4, Bild 1 von 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: Schritt 7, Bild 1 von 3 HP Compaq nc6400 Screen Replacement: Schritt 7, Bild 2 von 3 HP Compaq nc6400 Screen Replacement: Schritt 7, Bild 3 von 3
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: Schritt 8, Bild 1 von 2 HP Compaq nc6400 Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: Schritt 10, Bild 1 von 2 HP Compaq nc6400 Screen Replacement: Schritt 10, Bild 2 von 2
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: Schritt 11, Bild 1 von 2 HP Compaq nc6400 Screen Replacement: Schritt 11, Bild 2 von 2
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: Schritt 12, Bild 1 von 2 HP Compaq nc6400 Screen Replacement: Schritt 12, Bild 2 von 2
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: Schritt 13, Bild 1 von 2 HP Compaq nc6400 Screen Replacement: Schritt 13, Bild 2 von 2
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Luis Vazquez
401 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-6, Forte Fall 2013 Mitglied von Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Nicely done. Thanks?
Peter Q. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 16
Insgesamt: 5,471
