Zum Hauptinhalt wechseln
HP Compaq nc8430 RAM Replacement
bryan ingram
bryan ingram und 5 weitere Mitwirkende
Zuletzt aktualisiert am June 17, 2019
1 - 4 Minuten
Leicht
Fehlende Angaben
This guide will show you how to remove the RAM from a HP Compaq nc8430.
Was du brauchst
  1. HP Compaq nc8430 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 RAM Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: Schritt 4, Bild 1 von 1
    • Completely shut down the device and unplug any adapters and chords that are connected.
  5. HP Compaq nc8430 RAM Replacement: Schritt 5, Bild 1 von 1
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: Schritt 6, Bild 1 von 1
    • Locate the RAM after you remove the covering.
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: Schritt 7, Bild 1 von 1
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: Schritt 8, Bild 1 von 1
    • Place your fingers firmly on the RAM and pull it up.
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: Schritt 9, Bild 1 von 1
    • Place fingers firmly on RAM and pull it to remove it.
Abschluss
bryan ingram
101 Reputation
1 Anleitung geschrieben
Texas Tech, Team S13-G4, Bennett Spring 2017 Mitglied von Texas Tech, Team S13-G4, Bennett Spring 2017
TTU-BENNETT-S17S13G4
5 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 773
