Zum Hauptinhalt wechseln
HP Compaq nx7400 Sreen Frame/Hinge
David Salerno
David Salerno und eine weitere beteiligte Person
Zuletzt aktualisiert am February 19, 2016
Keine Schätzung
Leicht
Anleitung eines Community-Mitglieds
This guide will walk through the steps to replacing the frame and hinge on a HP Compaq nx7400 laptop.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Compaq nx7400 Sreen Frame/Hinge, Screen Frame/Hinge: Schritt 1, Bild 1 von 1
    • Here you can see where the hinge broke.
    • Remove the screw shown, and set it aside you will need it later for re assembly.
    • This screw is normally hidden under the rubber pad above it.
  2. HP Compaq nx7400 Sreen Frame/Hinge: Schritt 2, Bild 1 von 1
    • Remove all the rubber pads around the screen using your finger nails or a knife if you are having trouble.
    • once the pads are removed, use the torx screwdriver to remove the screws around the screen
  3. HP Compaq nx7400 Sreen Frame/Hinge: Schritt 3, Bild 1 von 2 HP Compaq nx7400 Sreen Frame/Hinge: Schritt 3, Bild 2 von 2
    • Once the screws are all removed pry up the black frame and carefully pull it free
    • Be careful not to snap any thing, you can use a screw driver with some gently pressure if you have having trouble.
  4. HP Compaq nx7400 Sreen Frame/Hinge: Schritt 4, Bild 1 von 1
    • Locate these 2 screws on the back and remove them.
    • You can use either a flat head or a Torx bit. I found the flat head easier for these screws.
  5. HP Compaq nx7400 Sreen Frame/Hinge: Schritt 5, Bild 1 von 1
    • Carefully pry up the panel with the power button to locate this screw. It is under the raised portion connecting the screen with the rest of the laptop.
    • This was the hardest screw to remove because the panel is difficult to pull up. I pulled it up just enough to get my screw driver in there.
    • The screw goes through the cable in the picture, make sure to keep it in there when you put the new hinge in.
  6. HP Compaq nx7400 Sreen Frame/Hinge: Schritt 6, Bild 1 von 1
    • Lift the screen from the top and remove the screws on the side.
    • Now you can pull the old hinge assembly out.
  7. HP Compaq nx7400 Sreen Frame/Hinge: Schritt 7, Bild 1 von 1
    • Place the new hinge assembly in and replace all screws.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
David Salerno
823 Reputation
4 Anleitungen geschrieben
4 Kommentare
Here it is mentioned that you need a T10 torx screw driver. But that is not right. I bought a T10 and found that is too large. Later I found in the HP repair manual available at http://www.manualslib.com/download/27316..., that the screw size is T8 Torx.
Zohan Done - Antwort
I had to replace both the hinges and had a donor laptop. this is how i found out that if you take off the top bezel(where the switches live) near the screen by removing three wide black screws under the battery, you don't have to pry open the two halves to reach the top screw on the hinge. for easier removal of the top bezel i removed the keyboard also by loosening the screws on the underside and unhooking the four clips which can be found between the keys. this manual was still a great help to get me started and familiarize myself with the different components.
Pieter Hansma - Antwort
Hello there,
My HP Compaq 7400's screen casing is broken along with the hinges and I literally have to make it lean on something like a wall.
I'm looking for the whole thing. Can you help me?
Thanks in advance.
It is Pretty Funny - Antwort
Where can I get a replacement hinge - maybe two?
Task looks simple enough - thanks for a good description!
John P
John Pink - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 9,551
