HP EliteBook 840 G7 Heatsink Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide is to instruct you in the proper removal and replacement of the Heatsink in an HP EliteBook 840 G7. Use this guide if your computers Heatsink stops working.
Was du brauchst
Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
Remove the connector that connects the battery to the motherboard.
Use a Phillips # 1 screwdriver to remove the three 5mm screws from the fan housing.
Remove the fan from computer.
Use a Phillips # 1 screwdriver to remove the four 4mm screws from the heatsink.
Remove the heat sink from computer.
