Zum Hauptinhalt wechseln
HP EliteBook 840 G7 Trackpad Replacement
James Kegan Roush
James Kegan Roush und 3 weitere Mitwirkende
Zuletzt aktualisiert am March 20, 2025
3 Minuten
Mittel
Anleitung eines Community-Mitglieds
This guide is to instruct you in the proper removal and replacement of the Trackpad in an HP EliteBook 840 G7. Use this guide if your computers Trackpad stops working.
Was du brauchst
Werkzeuge
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mehr anzeigen …
  1. HP EliteBook 840 G7 Trackpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Trackpad Replacement: Schritt 4, Bild 1 von 3 HP EliteBook 840 G7 Trackpad Replacement: Schritt 4, Bild 2 von 3 HP EliteBook 840 G7 Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Trackpad Replacement: Schritt 5, Bild 1 von 3 HP EliteBook 840 G7 Trackpad Replacement: Schritt 5, Bild 2 von 3 HP EliteBook 840 G7 Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 1
    • Unplug the ribbon cables from the track pad assembly.
  7. HP EliteBook 840 G7 Trackpad Replacement: Schritt 7, Bild 1 von 2 HP EliteBook 840 G7 Trackpad Replacement: Schritt 7, Bild 2 von 2
    • Use the Philips # 1 screwdriver to remove the four 2.2mm screws securing the track pad assembly.
  8. HP EliteBook 840 G7 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Remove the track pad.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
laptop treckpad automatically get clicked while speaker produced a sound
Govind Bhardwaj - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 52
Insgesamt: 1,046
