HP Envy 17-3070NR Wireless Card Replacement
Einleitung
Zu Schritt 1 der AnleitungA wireless card gives your laptop access to the internet, therefore it is one of the most important components for many. If the wireless card fails use this guide to replace it in your HP Envy 17-3070NR.
Was du brauchst
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the six 3.7mm Phillips screws.
Slide the back cover until it clicks, then lift it straight off.
Unscrew 4.5mm Phillips screw.
Unplug both antenna connectors by carefully pulling them upwards.
