Zum Hauptinhalt wechseln
HP Envy 17-J013CL Back Panel Replacement
Matt McBride
Matt McBride und eine weitere beteiligte Person
Zuletzt aktualisiert am April 17, 2017
1 Minute
Leicht
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
The back panel on the HP Envy 17 is a simple plate that covers the underside of the laptop. Once removed it gives easier access to laptop components such as the WLAN module and RAM module. This is a crucial step in order to delve deeper into the device.
Was du brauchst
Werkzeuge
  1. HP Envy 17-J013CL Back Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Back Panel Replacement: Schritt 3, Bild 1 von 3 HP Envy 17-J013CL Back Panel Replacement: Schritt 3, Bild 2 von 3 HP Envy 17-J013CL Back Panel Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Back Panel Replacement, Back Panel: Schritt 4, Bild 1 von 2 HP Envy 17-J013CL Back Panel Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Back Panel Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
Abschluss
To reassemble your device, place the back panel from opposite the battery end in the slots and place down until it snaps into place.
Matt McBride
872 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 16-6, Blackwell Spring 2017 Mitglied von USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 40
