HP Envy 17m-ae111dx Screen Replacement
Einleitung
Zu Schritt 1 der AnleitungIs your HP Envy 17m-ae111dx screen broken? If so, here is the guide to fix the problem with a replacement of the of laptop screen. All you will need is the iFixit Opening Tool and iFixit iOpener Tool. For more information on how to properly use the iOpener, please visit and read through the iOpener instructions.
Was du brauchst
Microwave the iOpener Device for 30 seconds. For more instructions on how to properly use the iOpener, please read through our iOpener instructions.
Lay the clear side of the iOpener down on the outer edge of the screen to melt the adhesive.
Use the iFixit Opening Tool to pry open the screen.
Use the iFixit Opening Picks to scrape off the excess glue.
Disconnect the power wire.
Disconnect the display wire.
Remove the screen from the device.
Ein Kommentar
Thanks and by the way this is also equivalent to an hp envy 17-ae013ca
