Zum Hauptinhalt wechseln
HP Envy 4-1030us Hard Drive Replacement
Was du brauchst
  1. HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Envy 4-1030us Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • After removing the cover the mSATA SSD should be visible near the center of the device.
    • Remove the one Phillips 2.5mm screw holding the SSD in place. The drive should pop up after removing the screw.
  4. HP Envy 4-1030us Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • To remove the SSD grab the edges and pull it from the slot.
    • Try not to touch any pins or connectors. Damaged pins could result in permanent damage to the system.
Abschluss
USF Tampa, Team S1-G1, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 846
