HP Envy 4-1030us Hard Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will walk you through the steps required to replace the mSATA solid state drive. Replacing the drive is necessary when it is damaged or you want to upgrade.
When working with electronic components, we recommend wearing an electrostatic wristband, it is possible for the static electricity present on you to discharge onto one of the components, wearing one of these wristbands and clipping it to a piece of metal will prevent this from happening.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
Lift the bottom cover off of the system.
Remove the one Phillips 2.5mm screw holding the SSD in place. The drive should pop up after removing the screw.
