HP Envy TouchSmart 15 RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungReplacing the RAM module might be necessary if you have random crashes and blue screens of death. Be sure to test them before you condemn them to the trash.
Was du brauchst
Werkzeuge
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
You can now remove the RAM modules you need to replace. You can replace the top one, the bottom one, or both if needed.
3 weitere Personen haben diese Anleitung absolviert.
