Zum Hauptinhalt wechseln
HP Envy dv6-7363cl Fan Replacement
dylananthony
dylananthony und 7 weitere Mitwirkende
Zuletzt aktualisiert am March 20, 2025
25 Minuten
Mittel
Reader will be able to successfully replace their fan assembly in the device. A basic understanding of simple tools such as a screwdriver is needed. Any form of electricity must be removed from device, including the charging cable and battery. Reader will need to be able to gently disassemble almost entire laptop.
Was du brauchst
Ersatzteile
Werkzeuge
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Mehr anzeigen …
  1. HP Envy dv6-7363cl Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: Schritt 2, Bild 1 von 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Fan Replacement: Schritt 3, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: Schritt 4, Bild 1 von 1
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: Schritt 6, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 6, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 6, Bild 3 von 3
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: Schritt 7, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 7, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 7, Bild 3 von 3
    • Lift the keyboard out of the device
    • Carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: Schritt 8, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 8, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 8, Bild 3 von 3
    • Flip device onto its back
    • Remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: Schritt 9, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 9, Bild 2 von 2
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: Schritt 10, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 10, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 10, Bild 3 von 3
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: Schritt 11, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 11, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 11, Bild 3 von 3
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: Schritt 12, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 12, Bild 2 von 2
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: Schritt 13, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 13, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 13, Bild 3 von 3
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: Schritt 14, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 14, Bild 2 von 2
    • Turn device onto its back and remove circled screws from Wi-Fi card.
    • Flip device back over and unscrew disk reader
  15. HP Envy dv6-7363cl Fan Replacement: Schritt 15, Bild 1 von 1
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
dylananthony
564 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Antwort
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 30
Insgesamt: 4,632
