Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Place the computer on its top on a flat surface with the hinges facing away from you.
Slide the battery release latch to the left which is located on the right-hand side of the battery.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Slide the service cover toward the front of the laptop.
Lift the service cover to remove it from the laptop.
Press down and away from the ram cards on the tabs surrounding the ram cards.
Fast fertig!
Abschluss
