HP Envy x360 m6-aq103dx Bottom Cover Replacement
Einleitung
Zu Schritt 1 der AnleitungIn order to remove the bottom cover, you will need the nylon spudger and the Phillips 1 Screwdriver Head.
Was du brauchst
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
8 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
But where can i purchase the bottom cover
