HP Envy x360 m6-aq103dx RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungThis is a guide to replace the RAM in the laptop. You will only need the anti-static wristband for this guide.
Was du brauchst
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
Lift up the port with the tool.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove the ram’s metal cover with your hand.
Pull the two outer pins on either side of the ram chip outward with your hands.
Do this for both chips.
Remove the chips one at a time, by sliding them towards the side of the computer they are pointing towards.
2 weitere Personen haben diese Anleitung absolviert.
